file copy: difference between FME 2020.0 and FME 2022.1
  • Oct 3, 2022 7:10 AM UTC
  • 54 views
vki
Forum|alt.badge.img+8
Hello
We just updated FME from 2020.0 to 2022.1.
I wanted to use a workspace with a file copy writer in it. It still works and copies files.
I wanted to change something, but in the file copy writer- dialog there's one tab missing and I cannot fill in anything.
That's how it looked in FME 2020.0
file copy in FME 2020.0That's how it looks now in FME 2022.1
FME2022.1Is this a bug or how can I change the parameters?
Thanks in advance
Vera
cory
Forum|alt.badge.img+7
  • Oct 3, 2022 7:13 AM UTC
Hi @vki​
The two screenshots you've sent through appears to show one as Format Attributes and the other as User Attributes.
If you need this as a User Attribute, I would suggest either exposing the Format Attribute or creating a user attribute for this.
vki
  • Oct 3, 2022 7:38 AM UTC
Thanks @cory
So I have to add an additional step to be able to copy files. It used to be easier...
imageThanks
Vera
