FeatureReader doesn't output a schema object from a file geodatabase feature class
  • Nov 30, 2016 3:36 PM UTC
  • 113 views
I've got a shape file and a GDB feature class derived from that. 2 featureReaders with the same settings pointing at the 2 datasets, the shape file reader outputs a schema feature the GDB reader does not.
Anyone know what's going on here? FME Desktop 2016.0
mark2atsafe
Forum|alt.badge.img+59
Hi @shepthedog63
Do the feature types have the same names in both datasets? ie the Shape file is also called EA_NE_AREAS? It seems to be a recently discovered issue that if so only one returns a schema.
It's filed as PR#71993 and I will add a link to this thread and increase the priority.
If that's not the case, then let me know and I can look further - or contact our support team (safe.com/support)
Hi Mark,
The feature type names are the same in both but after further digging that existing PR doesn't seem to fit my symptoms:
I've mailed you a zip with 2 .gdb's in it (too big to attach here. 1Mb limit a bit stingy).
The schema is not output from test_bad.gdb even when it's the only feature type being read (delete the other featureReader).
The schema is output from test_good.gdb even when it's the 2nd feature type being read (after test_bad).
If I read from test_good.gdb and another copy like it, both schema features are output.
P.S. feature type name does have something to do with it, though: if I say 'Feature Types to Read: <All Feature Types>' instead of specifying my feature class test_bad.gdb does output schema object.
Regards,
Ian
