Feature Read/Write count in FME Server response
  • Dec 18, 2017 7:15 AM UTC
  • 97 views
Can i get the Number of features read by FME workbench as like NumFeaturesOutput in response variable while running it as Jobsubmitter or Data Download Service?
nielsgerrits
Forum|alt.badge.img+67
I would use the an HTTPCaller to request the API to get this information, using the jobid which the Jobsubmitter returns. It's an easy GET.
https://<fmeserveradres>/fmerest/v2/transformations/jobs/id/<jobid>/result?accept=json&detail;=high
See https://docs.safe.com/fme/2016.1/html/FME_REST/v2/apidoc/
Tab API
GET /transformations/jobs/id/< jobid >/result Retrieve a job's transformation result
Be aware: This only works when using classic writers. When using FeatureWriters, the numFeaturesOutput are not updated, yet.
My workaround for this is to write the result summary to a dedicated database table and read that record when needed.
  • Dec 18, 2017 8:48 AM UTC
Tab API
But with this i can only get the NumFeaturesOutput i.e count of features written by workbench not the Count of features read by workbench.
nielsgerrits
Yes it is a bit limited. But as we have Workbench we are almost able to solve everything. Use a dedicated database table to write job summaries how you like them. Database can be Excel as well.
