Fanout to KML and not KMZ
  • Dec 3, 2015 6:24 PM UTC
  • 67 views
I have a single KML file that I am trying to use fanout based on "name" field to new separate KML files for either polyline from the original file. When I turn fanout to yes I will get .KMZ's for every file. Is there something I'm missing that I can set to force KML's and not KMZ's?
Best answer by erik_jan
If you use .kml as a suffix in the dataset fanout, it will create KML files.
erik_jan
Forum|alt.badge.img+26
  • Dec 3, 2015 6:35 PM UTC
  • Dec 3, 2015 7:13 PM UTC
Perfect. Knew it had to be something easy. Thanks.
