Expose unknown Civil Property Sets by prefix - dynamic writer
  • Jan 14, 2020 2:45 PM UTC
  • 6 replies
  • 104 views
jasperwis
Forum|alt.badge.img+19
Goal of this workbench was to be able to expose the property sets attributes of a Civil dwg, without knowing the attribute names. I am only interested in the property sets starting with a fixed prefix. I have started from some python code I found here: python attribute names
Topic is related to:
https://knowledge.safe.com/idea/18842/bulkattributeexposer-expose-all-possible-attribute.html
https://knowledge.safe.com/questions/32777/how-to-expose-all-attributes-in-generic-way-any-ma.html
Since I don't know the attribute names beforehand, I have to use a dynamic writer.
First I was trying to avoid this, since I am not familiar with the dynamic workflow, so I was writing everything to a json string, so that I was able to write all desired output. But now I am trying to use the dynamic writing functionalities.
I have 2 questions:
1/ the attribute names in the shapefile output are too short (have a length of only 1-3 characters). How can I fix this?
2/ Is it possible to put all exposed attributes into the FME table? The complexity is that I don't know the amount of attributes and the attribute names beforehand, so I cannot use the AttributeCreator. Or is there a way to create attributes based on a list (not having to save the list and importing it back)?
Jasper
Forum|alt.badge.img+54
  • Jan 14, 2020 3:25 PM UTC
Issue 1 is because you cannot create attributes with the names you are trying to create
e.g. it is not possible to create a shapefile attribute with the name LIB - set1.prop1 - the spaces, and characters (- and .) as well as the overall length are all problems here.
jasperwis
  • Jan 15, 2020 8:13 AM UTC
Thank you, wasn't aware of this. Field name length limited to 10 characters.
Any idea for issue 2?
  • Jan 15, 2020 8:16 AM UTC
I'm not sure what you mean by FME table
jasperwis
  • Jan 17, 2020 3:45 PM UTC
I mean over here:
or here:
So I can use these attributes in the next steps of the workbench.
If I would know the names and the amount of attributes beforehand, I could add a AttributeCreator before the PythonCaller. But I don't. So basically, I am looking for a way to add these attributes (found in the Python script) to the output port of the PythonCaller.
  • Jan 17, 2020 6:25 PM UTC
I mean over here:
or here:
It's not possible to do what you are suggesting. If it is a dynamic workflow there is no need to expose the attributes in the workspace.
jasperwis
  • Jan 20, 2020 7:49 AM UTC
There is one need in my point of view: using those attributes further one in the workbench in the standard transformers. I catch those values in the pythoncaller, but they stay more or less unexposed.
