Error handling in FME
  • Jun 24, 2014 4:22 AM UTC
  • 255 views
Hello,
I am developing workbenches that will process the input data depending on certain conditions. I am publishing to FME server so that it can be used in Java application.
I would like to know is it possible to pass any meaningful error message if data is not what is expected. I don't have a clue how I could achieve this. Any pointers in right direction?
  • Jun 24, 2014 6:40 AM UTC
have you looked at the  FME Server REST API (http://docs.safe.com/fme/html/FME_REST/)? It will give you the result of a translation.
David
Link was broken.. :(
LizAtSafe
Forum|alt.badge.img+26
  • Dec 1, 2017 8:40 PM UTC
Hi @kanthsri74, here is the new link. https://docs.safe.com/fme/html/FME_REST/apidoc/v3/#
