Dynamic writers - is it possible to use a wildcard in the Attributes to Remove ?
  • Nov 6, 2015 8:36 AM UTC
  • 107 views
I am using a dynamic reader (WFS) that will have multiple datasets with different attributes going through it.
Using a dynamic writer , I want to be able to use a wildcard in Attributes to Remove to remove any attribute that has the suffix : xsi_nil.
I have been trying to use variations on ' *xsi_nil ' but it doesn't seem to like wildcards , or have I just not hit on the correct syntax?
Thx
  • Nov 6, 2015 8:46 AM UTC
Hi
I suspect that this a list of constants, and that wildcards aren't supported.
David
  • Nov 6, 2015 8:53 AM UTC
As David mentioned, I don't think it's possible to use a wildcard in the parameter setting. You may have to read schema features from the source dataset, modify the schema contents ("attribute{}" list), and configure the dynamic writer with this method.
Destination Schema is Derived from List Attributes
Takashi
