Dynamic writer put the new attribute as first column
  • Aug 4, 2017 2:45 PM UTC
  • 74 views
Hello,
I have a simple dynamic workflow with Shapefile reader and Oracle writer (something like that) where I had a counter to add an ID in a new column "OBJECTID". This works well but my new column is added at the end of the schema. Is there a way to put this as first column?
Thank you!
Maxime
trentatsafe
Forum|alt.badge.img+7
Hello @bescu,
I believe there are a few methods in which you could achieve this. To name two possible options:
1) There is a custom transformer on the FME Hub that will reverse the attribute order. ReverseFeaturesOrder.
2) With using a dynamic workflow, it may be best to try modifying the schema using a the SchemaSetter and lists. An example can be found here: https://knowledge.safe.com/articles/43899/dynamic-workflows-advanced-example-modifying-the-s.html
There are many more options that may achieve the result you are expecting, and they can be found throughout the Dynamic tutorials. Here is the link to them.
https://knowledge.safe.com/articles/1050/dynamic-workflow-tutorial-introduction.html
fmelizard
Forum|alt.badge.img+22
  • Aug 4, 2017 5:14 PM UTC
Hi @bescu, I would recommend checking out the SchemaSetter transformer. Later on, in that tutorial series, there is an example using the transformer to modify the schema .
danilo_fme
Forum|alt.badge.img+58
  • Aug 4, 2017 5:29 PM UTC
Hi @bescu, did you change the position in Feature Type your Writer :
Thanks,
Danilo
