Dynamic schema creation failing for Esri Guid
  • Jul 26, 2019 4:01 AM UTC
  • 50 views
todd_davis
Forum|alt.badge.img+23
I am creating a dynamic schema from a list, however when I am trying to create a GUID in an Esri File Geodatabase it is showing the field as text (using both writers and changing the format_short_name). What's more annoying is this same example is shown in this article: https://knowledge.safe.com/articles/1051/index.html
Does this no longer work, or can you see an issue in this example??Guid.fmw
mark2atsafe
Forum|alt.badge.img+59
I think fme_format_short_name should be GEODATABASE_FILE and not FILEGDB. Hoping that makes the difference.
todd_davis
  • Jul 26, 2019 6:30 PM UTC
Hi @mark2atsafe,
Oops had a mistake in the example (have now corrected the attached example for FILEGDB), because I had been playing around with different FIle Geodatabase writers and obviously forgot to update the short_name on the one I loaded.
Unfortunately this isn't the fix though, as it still shows as text.
Cheers,
Todd
mark2atsafe
Hi @mark2atsafe,
Cheers,
Todd
I'm checking with the developers. My first thought is that the API (FILEGDB) format doesn't support this, although I don't see why. I'll let you know what I hear back.
