Double Transposing Attributes to Test for Attribute Names
  • Dec 12, 2016 11:29 PM UTC
  • 7 replies
  • 122 views
pcheng
Forum|alt.badge.img+8
Hello everyone!
Long time user of FME and a big lurker here!
I am currently designing a FME Server Workbench where I expect a user to upload spreadsheets that does not have any sort of schema requirements aside from Lat/Long and a prefix of 'h_' for any hyperlinks in their spreadsheet.
I currently have two branches in my workbench
BRANCH 1
With Dynamic Reader and Writers the process is relatively simple, but my issue is with the hyperlinks. My hyperlink URLs need to be wrapped with <a href> </a> tags in order to work on web app builder mapping services. This branch creates the points out of the provided Lat/Long and accepts schemas for an increase in character width for larger hyperlinks
BRANCH 2
In order to test attribute names that contain 'h_', I used an attributeexploder and was able to determine which fields have a h_ thus needing the <a href> tags. Once I have the <a href> tag in place I want to transpose it again to return it to the original state with the attribute names being the fields with 'h_' and to reconnect it to branch 1
My issue:
In branch 2 my transposition does the job of identifying my 'h_' fields, but afterwards my attempts to transpose it again is failing me! Does anyone know a solution to rebuilding attributeexploded/aggregated lists?
Hopefully I have conveyed my issue clearly otherwise I will be checking over this post for more questions.
Thanks,
Patrick
Best answer by takashi
Hi @pcheng, if I understand the requirement correctly, the workflow in the attached workspace might help you: format-urls-example.fmw (FME 2016.1.3.1)
format-urls-example
Python Edition:
def formatURLs(feature):
    for attr in feature.getAllAttributeNames():
        if attr.startswith('h_'):
            v = feature.getAttribute(attr)
            feature.setAttribute(attr, '<a href="%s">%s</a>' % (v, v))
Tcl Edition:
proc formatURLs {} {
    foreach attr [FME_AttributeNames] {
        if {[regexp ^h_ $attr]} {
            set v [FME_GetAttribute $attr]
            FME_SetAttribute $attr "<a href=\"$v\">$v</a>"
daveatsafe
Forum|alt.badge.img+24
  • Dec 13, 2016 12:44 AM UTC
The easiest way to do this would be to use a PythonCaller to loop through all the attributes and replace the 'h_' with the tags:
import fme
import fmeobjects
import re
    # get names of feature attributes
    attNames = feature.getAllAttributeNames()
    # loop through attributes
    for att in attNames:
        # don't process generic attributes
        if not att.startswith('fme'):
            # get attribute value
            value = feature.getAttribute(att)
            # does attribute start with h_?
            if value.startswith('h_'):
                # replace h_ with tags
                newval = re.sub('^h_','<a href>',value) + '</a>'
                # write updated attribute back to feature
                feature.setAttribute(att,newval)
pcheng
  • Dec 13, 2016 3:50 PM UTC
import fme
import fmeobjects
import re
Hey Dave,
Using Python totally slipped my mind! I'm just having a bit of an issue using the pythoncaller transformer.
I get this error:
PythonFactory failed to load python symbol `FeatureProcessor'
Factory proxy not initialized
f_21(PythonFactory): PythonFactory failed to process feature
I am on
FME 2016.1 Build 16492
and using a
a custom python interpreter from C:\Windows\SysWOW64\python27.dll for importing arcobjects
I had no issues using startup and shutdown scripts!
jdh
Forum|alt.badge.img+41
  • Dec 13, 2016 4:01 PM UTC
Hey Dave,
I get this error:
I am on
and using a
a custom python interpreter from C:\\Windows\\SysWOW64\\python27.dll for importing arcobjects
in the PythonCaller parameter window, set the Class or Function to Process Features to formatURLS instead of FeatureProcessor
pcheng
  • Dec 13, 2016 4:42 PM UTC
Thanks! That allows me to run this python script.
But I get an error:
Python Exception <AttributeError>: 'int' object has no attribute 'startswith' Error encountered while calling function `formatURLs'
I've looked at attNames itself when I used these lines:
attNames = ','.join(feature.getAllAttributeNames())
feature.setAttribute('attNames', attNames)
It is a list but it's missing its prefixes that I expect like fme_ for object types and what not and I cannot expose it's elements neither!
I am getting closer though!
pcheng
  • Dec 13, 2016 11:44 PM UTC
No luck with Dave's code snippet. I got to a point where I was able to wrap one of the list elements from the getAttributeNames function with the regular expression. However with multiple 'h_' elements I cannot see through with this solution!
I'm looking using python to transpose the row to columns as my attributeexploded + aggregated list is extremely close to what I want!
  • Dec 14, 2016 8:49 AM UTC
format-urls-example
Python Edition:
Tcl Edition:
pcheng
  • Dec 14, 2016 3:33 PM UTC
format-urls-example
Python Edition:
Tcl Edition:
Thank you so much @takashi, all three of your solutions provides the results that I wanted to integrate into my workbench!
Lots to learn from these solutions as well! I appreciate the learning opportunity.
