Did safe remove ESRI File Geodatabase reader / writer?
  • Sep 19, 2024 10:25 PM UTC
  • 229 views
a-a-ron
Forum|alt.badge.img+4
Just started my new job and the work environments are very similar (ArcInfo / Advanced License; new office FME Professional edition - old office FME oracle edition) and all I can see is the Open FileGDB reader writer.
Wondering if safe discontinued the ESRI File GDB reader and writers?
ArcPro 3.3.2 - advanced
ArcMap 10.8.2 - info
FME 2023.1 - Professional
Best answer by bwn
The short answer is “No”: ESRI File GDB Reader/Writer are still present in FME 2023.1
Apart from the Open API Readers/Writers, for the ESRI GDB Readers/Writers FME does have dependencies on FME Versions, FME 32-bit/64-bit and and ArcGIS Configuration on the PC however.  See following resources that may assist.  Noted for example that FME2023.1 is not documented as supporting ArcPro 3.3.2 (well presumably not in FME 64 bit), with the min version of FME specified as FME 2024.0.2.2.
Otherwise we tend to run ArcMap 64 bit background geoprocessing module to use with FME 64 bit, but do not know how well that plays with an ArcPro install on same PC.
https://support.safe.com/hc/en-us/articles/25407724093837-Notes-on-FME-and-Esri-Versions-and-Compatibility
https://support.safe.com/hc/en-us/articles/25407455291021-Comparison-of-Esri-Based-Readers-and-Writers-in-FME
https://support.safe.com/hc/en-us/articles/25407504096909-Geodatabase-Formats-Missing-Greyed-Out-or-Have-Unmet-Dependencies
bwn
Forum|alt.badge.img+26
  • Sep 19, 2024 11:27 PM UTC
hkingsbury
Forum|alt.badge.img+73
  • Sep 19, 2024 11:33 PM UTC
There is still File Geodb which is the licensed reader/writer
a-a-ron
  • Sep 20, 2024 3:25 PM UTC
Thanks. It was version compatibility. Installing FME 2024 fixed the issue.
