DateTimeStamper set format out
  • Dec 21, 2022 3:30 PM UTC
  • 61 views
townest
Forum|alt.badge.img+4
Greetings,
Is there a setting to set the date value out of the DateTimeStamper to say ISO?
Thank you,
Tyler
FME 2022.1
Best answer by ebygomm
You can avoid the use of a DateTimeStamper and use the following in an AttributeCreator/AttributeManager to get the current date time and format it as required
@DateTimeFormat(@DateTimeNow(),%Y-%m-%dT%H:%M:%S)
hkingsbury
Forum|alt.badge.img+73
  • Dec 21, 2022 9:47 PM UTC
Sort of, pass the features into a datetimeconverter and from there you can change the format to ISO
thijsknapen
Forum|alt.badge.img+12
  • Dec 21, 2022 10:07 PM UTC
Indeed. Note that you can also create a custom transformer from this 'DateTimeStamper - DateTimeConverter' combination to form your very own ~'ISODateTimeStamper' ;)
Forum|alt.badge.img+54
  • Dec 22, 2022 9:38 AM UTC
