DateTimeConverter does not work when run on Server
  • Aug 13, 2019 9:18 PM UTC
  • 86 views
When running my workbench locally, there are no issues/errors. However, when I publish to the server and the workbench gets triggered by an automation, I get the following error in my log:
The clause 'TEST @Value(fme_rejection_code) != FEATURE_TABLE_SHIM_SUPPORT Yes' within 'FACTORY_DEF * TestFactory FACTORY_NAME Date_Converter_Rejector INPUT FEATURE_TYPE ___TOREJECTOR___ TEST @Value(fme_rejection_code) != FEATURE_TABLE_SHIM_SUPPORT Yes OUTPUT FAILED FEATURE_TYPE Date_Converter_OUTPUT @RenameAttributes(FME_STRICT,fme_rejection_code,___fme_rejection_code___)' is incorrect. TEST must look like: TEST <value> <operator> <value> [ENCODED]
Edit:
Just fyi, may have something to do with it: The DateTimeConverter is followed by a matcher.
Any help would be appreciated!
Thanks.
mygis
Forum|alt.badge.img+14
  • Aug 14, 2019 12:14 AM UTC
Just wondering, are the versions of Deskop and Server the same?
  • Aug 14, 2019 1:26 AM UTC
Desktop: 2019.1.0.0 (20190710 - Build 19608)
Server: FME Server 2019.0.2 (Build 19260)
  • Aug 14, 2019 3:50 AM UTC
Updating FME Server & Desktop has solved this issue. Kudos to @gisinnovationsb for the hint! Server version: 2019.1.1 (Build 19617). Desktop version: 2019.1.1.0 (20190801 - Build 19617).
mygis
  • Aug 20, 2019 9:59 AM UTC
Glad it worked for you.
