DateDifferenceCalculator
  • Apr 20, 2017 2:39 PM UTC
  • 5 replies
  • 188 views
jtn40764
Participant
I try to calculate the difference between to dates. I need the result in Years. From the FME HUb I get the
DateDifferenceCalculator. I runs good for difference in days or weeks. But how can I get the result in month or years?
Best answer by ciarab
The DateTimeCalculator in 2017 allows you to do this quite easily
It looks like the units are set within the custom transformer as a parameter with an alias.
You can edit the definition of the parameter.
Within the configuration section, you can add a new choice with an alias. An alias would be the number of seconds in a month or year. I assume this wasn't included as the number of seconds in a month or year vary and therefore any output wouldn't be accurate.
gio
Forum|alt.badge.img+15
  • Apr 20, 2017 3:08 PM UTC
see topic yesterday..
[clock format [clock scan today] -format {%j}] - [clock format [clock scan {YourAttribute}] -format {%j}]
(difference compared to today..)
replace %j (for days of year) with %W (for weeks of year) to get weekdifference.
To calculate daydifference over years ( over yearboundaries) you need to check if year is a leapyear
Or do clock scan and then use one of common calculations.
ciarab
Forum|alt.badge.img+10
  • Apr 20, 2017 3:09 PM UTC
  • Apr 20, 2017 3:27 PM UTC
If you can't upgrade to FME 2017 just yet, here's a quick Python solution for a PythonCaller. Expects the input attributes "start_date" and "end_date" on the format YYYYMMDD, outputs the attribute "difference_in_years":
from dateutil.relativedelta import relativedelta
from datetime import datetime
def CalculateYearsElapsed(feature):
    start_date_str = feature.getAttribute("start_date")
    end_date_str = feature.getAttribute("end_date")
    start_date = datetime.strptime(start_date_str, '%Y%m%d')
    end_date = datetime.strptime(end_date_str, '%Y%m%d')
    difference_in_years = relativedelta(end_date, start_date).years
    feature.setAttribute("difference_in_years", difference_in_years)
jtn40764
Participant
  • Participant
  • Apr 21, 2017 6:32 AM UTC
Thank you for your help. It runs.
