Custom Transformer - Overwriting Input Attribute
  • May 4, 2017 4:58 PM UTC
  • 74 views
dfresh
Hey Folks,
how do you set an output attribute in a custom transformer. I could always just use an attributecreator after and set attribute a to the output field. but would rather handle it in my custom transformer.
Attribute A = 1 before transformer
Attribute CustomOutputValue = 2 after transformer
Attribute A = 1 After transformer
but I want Attribute A = 2 after transformer.
note - the numbers in above example are simplified.
Thanks,
Doug
Best answer by takashi
Hi @dfresh, alternatively, if you have created an "Attribute Name" type published user parameter in the custom transformer, you can pass an attribute name to the custom transformer via the parameter and then overwrite its value with AttributeCreator etc.
Custom Transformer Definition
Main Workflow
jdh
Forum|alt.badge.img+41
  • May 4, 2017 5:47 PM UTC
Use a StringConcatenator inside your custom transformer and publish the New Attribute as a parameter. Inside the custom transformer it will appear as $(Attr) outside the custom transformer it will appear as whatever value you set the parameter to.
  • May 5, 2017 2:45 AM UTC
Main Workflow
