Custom coordinate system for EPSG:3275
  • Aug 21, 2017 2:11 PM UTC
  • 114 views
Hi, for my first time I need to define a Custom Coordinatesystem - since EPSG:3275 is not defined in FME.
I have made the following entry under \Documents\FME\CoordinateSystems:
COORDINATE_SYSTEM_DEF WGS84.SCAR-SU01-05        \
DESC_NM "WGS84 /SCAR IMW SU01-05"               \
DT_NAME WGS84                                   \
EL_NAME WGS84                                   \
MAP_SCL 1                                       \
ORG_LAT -80.23861111111111                      \
ORG_LNG -165                                    \
PROJ PSTERO                                     \
SCL_RED 1                                       \
UNIT METER                                      \
X_OFF 0                                         \
Y_OFF 0
I do:
- Creator, create point with X -160 and Y -82
- Set CoordinateSystem to "LL-WGS84"
- Reporject to "WGS84.SCAR-SU01-05" (my defined system) gives an error :
Reprojector(TeeFactory): Reprojector: Reproject: Could not reproject the geometry of the preceeding feature: Reprojector: Could not create reprojection engine
Anyone who can help on this? I expect I have some failure in the definition of the coordinate system..
See for example http://georepository.com/crs_3275/WGS-84-SCAR-IMW-SU01-05.html for the definition of EPSG:3275.
Thanx!
Pål Herman
Best answer by daveatsafe
Hi @paalsund,
I'm sorry, but FME currently has an issue converting Polar Stereo projections from Esri WKT to Csmap definitions.
Please change the projection in your definition from PSTERO to PSTEROSL in the test_3275 coordinate system created by the web form to get the correct results in your reprojection.
fmelizard
Forum|alt.badge.img+22
  • Aug 21, 2017 3:39 PM UTC
Hi @paalsund, there is a Safe hosted page that will allow you to create and define a custom coordinate system. This may help with the error you are seeing. Please check out How do I create a custom coordinate system
  • Aug 22, 2017 6:56 AM UTC
Thanks, my knowledge in polar stereographic is limited. I tried the method You supplied and got:
COORDINATE_SYSTEM_DEF test_3275 \\
DESC_NM "test_3275" \\
DT_NAME WGS84 \\
GROUP TEST \\
ORG_LAT -90 \\
ORG_LNG -165 \\
PARM1 -80.23861111111111 \\
PROJ PSTERO \\
QUAD 1 \\
SOURCE "http://spatialreference.org/ref/epsg/3275/" \\
UNIT METER \\
X_OFF 0 \\
Y_OFF 0
With FME I try the Reprojector with the above definition and the ESRIReprojector with the ESRI definition of EPSG:3275. The results are not very similar I am afraid :/
  • Aug 24, 2017 11:41 AM UTC
@TiaAtSafe. There is a problem here and it must be related to a scalefactor which is not calculated in the webservice, nor given as mandatory for the PSTERO projection at http://docs.safe.com/fme/2017.1/html/FME_Desktop_Documentation/FME_Coordinate_Systems/CoordSys/Projections/Proj_PSTERO.htm?
PARM1 is the latitude of the standard circle for the PSTERO projection, and if I get it right means the scalefactor of the projection is 1 at this latitude (-80.263... in the case of EPSG:3275) hence the scale at the south pole (-90 lat) is not 1. Seems to me PSTERO implement SCL_RED 1 if this parameter is not given in the custom coordinate system file? Would appreciate if You could give it a try, and for example calculate the example given at http://spatialreference.org/ref/epsg/3275/ which gives same result as ESRI Reprojector for point -165, -82.
daveatsafe
Forum|alt.badge.img+24
  • Sep 6, 2017 5:10 PM UTC
Hi @paalsund,
