Creating new sub folders when outputting data ?
  • Oct 19, 2017 2:12 PM UTC
  • 145 views
lifalin2016
Forum|alt.badge.img+42
A customer requests a nation wide set of themes to be "cookie-cut" into separate municipalities. Each municipality should have a complete set of themes in its own sub folder.
I'm using a dynamic output to TAB, with Table name set to:
(A)Value(MUNICODE)\\(A)Value(fme_feature_type)
But FME just substitutes the "\\" (and "/") with an underscore, so all tables end up in the same folder.
Is there a way to tell FME to create the sub folders and put data into these ?
Cheers
Best answer by david_r
The tablename corresponds to the filename, that's why FME won't allow slashes.
You can specify the output directory in the "fanout dataset" settings in the Navigator.
  • Oct 19, 2017 2:18 PM UTC
lifalin2016
  • Oct 23, 2017 9:06 AM UTC
Thanks David. I'm still new to "dynamic", but it seems this did the trick.
