Creating a custom FME function with c++
  • Apr 7, 2016 7:57 AM UTC
  • 8 replies
  • 126 views
ahuarte47
Forum|alt.badge.img+4
Hi, I would like to create a new custom FME function similar to current "UUID()" function. I have successfully built and tested the "CenterOfMass" C++ sample of the SDK "pluginbuilder" folder.
But I have a few questions:
  • The function only works when it is copied in the "plugins" folder. It does not run when it is copied in a "Shared FME transformer" folder. Can I configure it? It is an issue when we have not write-privileges in this folder.
  • The new function is not recognized in the "Attribute Editor Form" as a valid function (Other functions provided by FME have blue color).
Can I configure it?
Also, I would like to define its syntax and parameters. Is it possible?
  • Possibly related with last question, To successfully run the function I must write "@Evaluate(@MyUUID(...))", it does not run with only "@MyUUID()". What is wrong?
Thanks in advance!
Alvaro
gio
Forum|alt.badge.img+15
  • Apr 7, 2016 3:29 PM UTC
a function must be evaluated?
ahuarte47
  • Apr 7, 2016 3:56 PM UTC
I must write "@Evaluate(@CenterOfMass())" for that my function is executed.
gio
  • Apr 8, 2016 12:04 PM UTC
That was somewhat a rhetorical remark...srry
afaik a function has to be evaluated Always..
mark2atsafe
Forum|alt.badge.img+59
I'd be surprised if you needed @Evaluate. After all, the transformer in that demo folder doesn't include it. Anyway, I've asked some folk at Safe to take a look. I've done a few searches but didn't find anything that would help me answer definitively.
mark2atsafe
Does this function return a number? I was thinking there's a difference between the text and arithmetic editors, but even then it should work without @Evaluate in a text editor as long as you don't include it in a mathematical formula in there. The only difference is it might be returned as a string, not a numeric attribute type, but we aren't great at handling data type inside a workspace yet, so the difference would be small.
ahuarte47
  • Apr 11, 2016 7:18 AM UTC
Thanks for your review. You are right, the transformer in the demo folder doesn't include it, but it seems necessary to run in the AttributeCreator panel. Regardless of type of value returned. Other issue is how I define the syntax of my function to be recognized by FME.
mark2atsafe
Hi Alvaro,
I've filed an enhancement request to have these editor dialogs automatically recognize custom functions. It is PR#69429 and we'll wait and see what our developers say.
I don't have an answer for your other question, but I do wonder if you can create your new UUID function as a custom transformer instead of trying to code a solution. Or, if you can code it in Python, then you have two options: either embed it inside a custom transformer using a PythonCaller transformer, or use FME's @Python function to execute it.
If you're determined to code a solution then I'd suggest you join our Development Partner Program. That program includes technical support for this type of issue, and can even include the ability to send a developer to our Vancouver office to work with our staff directly. You can find more information on our web site.
I hope this information is of use,
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc
ahuarte47
  • Apr 12, 2016 9:01 AM UTC
Hi Mark, thank you very much for your support!!!!
To avoid these issues, I created finally a custom transformer similar to "CenterOfMass" sample. It works for me, but it is a pity not to insert the function in a more appropriate manner. I must concatenate a transformer for each attribute to assign in my workflow.
Really the code is a bit more complicated, I use a c++/cli dll running as a wrapper to call a c-sharp/.NET module with the specific code to run (It must run as fast as possible and the python already developed has poor performace). It works fine and I get 2x or 3x of performance improvement, I congratulate you for the SDK and your product!
Alvaro
