Correct transformer for joinig to database tables
  • Jul 29, 2021 10:56 AM UTC
  • 83 views
I have to tables from ms sql server.
table A: Task_posting
table B: Task_analysis
They are joined by the transaction_id field.
Now I need to get all Fields from A and add line_cost, Line_qty and Line_unit from B.
What transformer is the best for this? I tried to use databasejoiner, but in the section "fileds to add" I cannot find the fields from table B
Forum|alt.badge.img+63
The DatabaseJoiner would be an obvious choice but you'll need to connect that to the SQL Server database before you can see tables/fields.
If you already have both tables as feature types in Workbench you can use a FeatureMerger or FeatureJoiner.
