CAT Reader in WorkspaceRunner can't receive any "attribute value" as input
  • Sep 24, 2019 3:26 PM UTC
  • 6 replies
  • 89 views
I have an FME workspace "A" using a CAT reader that works well.
I have another workspace calling it with a WorkspaceRunner, which goes through a bunch of files using a "Directory and File pathnames" reader.
In the workspaceRunner Parameters of workspace "A" and can't select "attribute value" from the "Directory and File pathnames" reader :/
I changed my workspace "A" for a plain text reader and now I can select "attribute value -> path_filename".
There seems to be a bug with the CAT reader inside a WorkspaceRunner :/
Am I doing something wrong?
Best answer by ebygomm
Can you take a screenshot of how the CAT Reader parameter is set up inside your child workspace, like this
Forum|alt.badge.img+54
  • Sep 24, 2019 5:44 PM UTC
  • Sep 24, 2019 6:29 PM UTC
Here you are:
itay
Forum|alt.badge.img+19
  • Sep 24, 2019 6:53 PM UTC
Hi @jb.gariepy,
I think @egomm is correct, notice that your CAT reader user parameter type is set to Filename (Exisiting) and not Filename (Multiple)
What happens if you change the type to Filename (Multiple)?
  • Sep 24, 2019 7:37 PM UTC
Here you are:
The attribute assignment set to off is what is preventing you using an attribute to assign the filename in the workspace runner
  • Sep 25, 2019 4:21 PM UTC
Got it! That was my problem!!! Thanks a lot!!
  • Sep 25, 2019 4:24 PM UTC
As mentionned by @egomm, Attribute Assignment has to be set to "Default" :)
Thanks for your help!!
