Can't name scans in an E57 point cloud file?
  • Mar 16, 2018 11:28 PM UTC
  • 83 views
When using the E57 writer, I've been unable to assign specific names to the scans in the point cloud file. In my case I only have three names, and those are in attributes waiting for a place to use them.
It seems the writer uses the file's basename for the first scan, and then appends _001, _002, etc. to any others.
I'm hoping there's more flexibility and that some smart person will tell me where to find it.
TIA
geogaard
Forum|alt.badge.img+15
  • Mar 19, 2018 1:31 PM UTC
Do you mean naming the output file with an attribute name? Or is this an attribute that should reside inside the E57 file?
If it's the first I have attached an image that would give you an idea how to name output files with an attribute
