Can I get FMEWorkspaceRunner to automatically read multiple files (one at a time) from a folder?
  • Dec 19, 2019 10:35 PM UTC
  • 120 views
I'm trying to demonstrate how FME (eventually FME Server) can automate a process for us. I have all of my NMEA data in one folder (they are stored by day in a given month; hence, there can be 700-800 NMEA files in each folder), and I can get the reader to read them all manually...but I would like to know if it's possible to get FMEWorkspaceRunner to automatically read and load all of the files in a folder that will then be converted.
The FMEWorkspaceRunner variable is set to: runner = fmeobjects.FMEWorkspaceRunner()
I tried to be sneaky and use parameters['SourceDataset_NMEA'] ='\\\\2018ais\\c$\\rawnema\\Feb2019\\*.nmea', but it did not work using runner.runWithParameters(workspace, parameters).
I can (of course) do it manually from Python by using runner.promptRun(workspace), but this then defeats the purpose of my Python script.
Is there a way to get the FMEWorkspace Runner to automatically read/load all of the files in a folder that will then be converted?
When loading all of the NMEA files manually from within the FMW it works perfectly, and converts all of the points directly into a file geodatabase.
Thanks
Best answer by ryanatsafe
I'd start with a `Directory and File Pathnames` reader to read in the file names. It will be a feature for each file. Then you can run those features through either the WorkspaceRunner or FeatureReader transformer.
ryanatsafe
Forum|alt.badge.img+11
  • Dec 19, 2019 10:51 PM UTC
  • Dec 19, 2019 11:45 PM UTC
@ryanatsafe Thanks Ryan...I will give that a try next to see how it works. I'm almost there...I have a few Python scripts all able to automate a geoprocessing sequence...this is the last step :-).
