Attributes from Old Workbench
  • Jul 23, 2013 8:09 PM UTC
  • 53 views
I created a workbench previously that read in Garmin waypoint information stored in an AutoCAD DXF file and converted into my GIS with a SQL Server DB.  This was before FME had a reader for the Garmin GDB file format.  I made a copy of that workbench and modified it to read the GDB file instead of the AutoCAD DXF.  Toward the end of the translation sequence I have an AttributeRemover to remove unused attributes, but I noticed that somehow the workbench still has some default AutoCAD attributes floating in there.  When I see the list of attributes I can remove, I see about 20 or so AutoCAD related attributes.
My question is this:  Is there a way to flush or reset the workbench so that it only contains attributes related to the current readers, writers, creaters, etc. or do I need to create the work bench from scratch in order to eliminate all these AutoCAD attributes?
fmelizard
Forum|alt.badge.img+22
  • Jul 23, 2013 8:24 PM UTC
You could use the attribute keeper at the beginning of your translation, to remove them.
Itay
  • Jul 23, 2013 8:50 PM UTC
Well I was looking for a way that wouldn't need to have an additional translator.  Anyone else have a suggestion?
Or just create a fresh workbench?
