Attribute within attribute
  • Oct 21, 2013 5:45 PM UTC
  • 10 replies
  • 88 views
I would like to do a  feature merge using the address fields in two tables. One address has the format of:
123 MAIN ST
The other table has the format of:
123 MAIN STREET VANCOUVER
I know that I can change the first to be exactly the same as the second, but then I have to do the same with
123 W 1ST AV
1323 W 1ST AVENUE VANCOUVER
...etc.
Is there a way to do an SQL-like "IN" for the merge? That is, to merge where the first address is IN the second?
Thanks
fmelizard
Forum|alt.badge.img+22
  • Oct 21, 2013 5:59 PM UTC
Hi
You can use SQL on the fly with the inlineqierier.
See:
http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/inlinequerier.htm
  • Oct 21, 2013 6:11 PM UTC
That's exactly what I need! Thanks.
fmelizard
  • Oct 21, 2013 8:26 PM UTC
Great to know btw you can use the IN operator also in the tester/testfilfer / attribute creator and also the fuzzy string comparer from the store can be useful
http://fmestore.safe.com/transformers/FuzzyStringComparer.htm
  • Oct 21, 2013 11:59 PM UTC
If the two tables are contained in the same database, you can also create a joined table using the SQLCreator or the SQLExecutor.
"cross join" is the point. But the concrete SQL statements are different depending on the database system.
An example for MS-Access; assume table1 has ShortAddress field and table2 has LongAddress field.
select t1.ShortAddress, t2.LongAddress
  from table1 as t1, table2 as t2
  where t2.LongAddress like (t1.ShortAddress & '*')
Alternatively, a series of several transformers including FeatureMerger, ListSearcher and ListIndexcer could be used.
1) FeatureMerger (FME 2013 SP2 or later)
table1 --> REQUESTOR
table2 --> SUPPLIER
Join On: Requestor = 1, Supplier = 1 (the same constant to perform unconditional merging)
Process Duplicate Suppliers: Yes
Supplier List Name: _candidate
2) ListSearcher: Input MERGED features from the FeatureMerger.
List Attribute: _candidate{}.LongAddress
Search For: ^@Value(ShortAddress).*
Index Attribute: _list_index
Search Type: First regular expression match
3) ListIndexer: Input FOUND features from the ListSearcher
List Index: _list_index
There is more than one way to skin a cat.
Takashi
  • Oct 22, 2013 3:00 AM UTC
In the SQLCreator or SQLExecutor, wildcard in the "LIKE" operator seems to have to be "%", even if the source format is MS-Access.
The SQLCreator with this statement works.
select t1.*, t2.*
  where t2.LongAddress like (t1.ShortAddress + '%')
gio
Forum|alt.badge.img+15
  • Oct 22, 2013 4:23 PM UTC
Yes more then one way ot hurt cats...
u can create a merge-attribute using a creator wherin u
use a tcl string function.
Like[string compare str1 strg2] , [string match str1 str2]
a range of usefull functions there.
I assume your tables are not in same order, else there would be no point to your question, you''l have to do full catresian product to find the matches(?)
  • Oct 22, 2013 4:57 PM UTC
I don't think you can use the tester here, though, can you? That is for comparing two fields in the same feature. What I want is an IN operator between two features.
  • Oct 22, 2013 11:23 PM UTC
I think the Tester can be also a way to skin a cat in a context like this:
FeatureMreger (unconditional merging) --> ListExploder --> Tester
Test Clauses: <full address>  |  Begins With  |  <short address>
"Like", "Matches Regex" or "Contains" could be a option depending on the situation. Won't hurt a real cat :-)
gio
  • Oct 23, 2013 3:00 PM UTC
You can use a tester.
But first u need to make all the combo's.
A cartisian product.
Like mr.Takashi said, unconditionally merge the tables.
Then u could build Str1 x Str2
(One way to do this i using a listbuilder using with a group by on Str1 and Str2. Then dump the duplicates, with a listduplicateremover.
Now what u are seeking is somewhere in this list.)
Or activate the list in the merger; again  what u are seeking is somewhere in the list.
Use something like
or regular fme stringsearch transformers.
Basicaly samish as mr. Takashi suggestion.
gio
  • Oct 23, 2013 3:01 PM UTC
i forgot...
It is all moot to Schroedingers cat.... ;)
