Attribute lookups
  • Jun 14, 2018 6:31 PM UTC
  • 6 replies
  • 216 views
Hello.
I am needing to lookup attribute values from my source table and lookup the attribute name and value in an excel file to return a the new mapped value. If the source attribute name and value matches the lookup list, return the new value.
I have tried different combinations of mergers, exploders, joiners. Its a massive dataset with dozens of attributes to lookup per record. Any guidance would be appreciated. The challenge mostly that source attributes to align are values in the lookup
For example:
Source Data Example
STATUSMANUFACTURERMATERIALCREATEDBY0
ABC_CO
John0ZYX_INC1John
0
ZYX_INCJohn
Lookup XLS
IDDOMAIN1ORIGVALUENEWVALUE1MANUFACTURERABC_COABCCO2MANUFACTURERZYX_INCXYZINC3MATERIAL UNKNOWN4MATERIAL1PLASTIC5STATUS0ACTIVE
Desired Target
STATUSMANUFACTURERMATERIALCREATEDBYACTIVEABCCOUNKNOWNJohnACTIVEZYXINCPLASTICJohnACTIVEZYXINCUNKNOWNJohn
Best answer by takashi
Hi @mhollas, a bit long story. Please find the attached workspace example.
attribute-lookup.fmwt (FME 2018.0.1.0)
Forum|alt.badge.img+63
Is there overlap in the values for the different columns? I.e. can STATUS be 1 too?
  • Jun 14, 2018 7:22 PM UTC
Yes there will be overlaps accross domains
That complicates matters. It does look like something the SchemaMapper should be able to handle, there's a tutorial that will help you get started with it.
  • Jun 15, 2018 8:22 AM UTC
  • Jun 16, 2018 4:11 AM UTC
Brilliant! My initial tests pass. Ill continue with this and report back. Thank you @takashi
  • Jun 16, 2018 4:45 AM UTC
Good to hear. If you are familiar with (or interested in) Python scripting, see also this one.
# PythonCaller script example
class FeatureProcessor(object):
    def __init__(self):
        self.lookUp = {}
    def input(self, feature):
        if feature.getAttribute('_is_lookup'):
            d = feature.getAttribute('DOMAIN1')
            o = feature.getAttribute('ORIGVALUE')
            n = feature.getAttribute('NEWVALUE')
            self.lookUp.setdefault(d, {})[o] = n
        else:
            for attr in [a for a in feature.getAllAttributeNames() if a in self.lookUp]:
                v = feature.getAttribute(attr)
                feature.setAttribute(attr, self.lookUp[attr].get(v, '<undefined>'))
            self.pyoutput(feature)
    def close(self):
        pass
