AddCodedValueToDomain - Possible with FME?
  • Feb 3, 2016 7:57 PM UTC
  • 101 views
sdepriest
Forum|alt.badge.img+9
I've been asked to see if its possible to maintain values in a coded domain on an ESRI Geodatabase. I would need to insert, update, and delete code/description combination records in the domain. I've found this article:
https://knowledge.safe.com/articles/886/working-wi...
but it's referring to updating a table that uses a domain, not the actual domain.
I know FME can call a python script like this from within FME...
arcpy.AddCodedValueToDomain_management(in_workspace="H:/MyDocs/geodbs/inspections/Inspections.gdb",domain_name="Structure_No",code="ABC-123",code_description="STRUCTURE 123")
But can FME do it directly?
Thanks,
Sarah
Best answer by fmelizard
We highly recommend that you use ArcGIS in order to create/define/alter your geodatabase domain definitions. But you can get at the domain definitions by reading in a geodatabase feature class that contains the domains you wish to alter using a FeatureReader. This would give you access to the underlying schema of the geodatabase where you could then try to make adjustments to domain definitions.
The syntax you would look for within the schema looks like this - coded_domain(<DomainName>:<DataType>:code:value:code:value:.....).
An example domain for street types might look like this - coded_domain(StreetType:char:A:Arterial:S:Secondary:R:Residential)
Again, this is not necessarily a technique we recommend given the complex nature of domains.
sdepriest
  • Feb 3, 2016 8:29 PM UTC
I guess I asked this question in the old Google Discussion Group, FMETalk.
https://groups.google.com/forum/#!topic/fmetalk/KTO4vfQvT6k
Any updated information since then? Any new capabilities in FME 2015 or 2016?
fmelizard
Forum|alt.badge.img+22
  • Feb 3, 2016 9:40 PM UTC
sdepriest
  • Feb 4, 2016 8:48 PM UTC
Thank you @HeatherAtSafe, I understand the recommendation. I don't particularly want to risk corruption to our geodatabase, so I will explain this to the requestor.
Sarah
