Access to CSV filename in python
  • Feb 15, 2017 3:18 PM UTC
  • 82 views
Hi there,
I am trying to digest multiple CSV files from within a certain directory. To do this, I have created a CSV Reader that has a Source CSV folder with the parameter: _"<my file path>\\*.csv"_.
I need to remove the processed file from this directory after processing which I would do via python shutdown script by getting the filename that has to be removed (actually - it would be moved into a directory).
In the past when I only processed one file, I was able to grab the file location directly from the reader, which is of course now the <filepath>*.csv .
I have used an Attribute-Exposer to get the filename- but I haven't figured out how to use it in my shutdown script? Am I missing something obvious here? Is there a way to either:
- set a Python variable with the filename (I would be surprised)
or
- set a publish parameter at run-time?
Thanks in advance!
Best answer by erik_jan
I have done this using the FileCopy Writer using the fme_basename attribute that contains the file name and path. In that case there is no need for Python.
erik_jan
Forum|alt.badge.img+26
  • Feb 15, 2017 3:21 PM UTC
Forum|alt.badge.img+7
Hi @robopetr
There is no possibility to retrieve attribute values in the shutdown script. You can however use parameters using the list FME_MacroValues['name_parameter']. The path can be retrieved and all csv-files can be fetched using this path.
Another solution is to expose the fme_ feature_type (so you get the name of every file) and make sure that one of the features (for example using a sampler grouped by the feature_type) is sent to a pythoncaller. Using FeatureHolders you can make sure this pythoncaller is only executed at the end.
A cleaner and easier solution.
I would go for this one ;)
itay
Forum|alt.badge.img+19
  • Feb 15, 2017 4:17 PM UTC
yes much better and you keep the overview of actions in the workspace and not "hidden" in the shutdown script
