Listing of used value in an Attribute
  • Jan 17, 2019 4:34 PM UTC
  • 70 views
Hi dear
Is ist possible to get a list of used values in an Attribute?
I have data in the inspector (100000 an more) and i will know which values are in one Attribute used.
thanks for an answer.
Best answer by danilo_fme
Hi @hannes
Please, take a look on the transformer ListBuilder.
In this transformer you choose the attribute that you want to get list of value.
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Jan 17, 2019 4:40 PM UTC
Hi @hannes
Thanks,
Danilo
  • Jan 18, 2019 12:34 AM UTC
I assume that you have two datasets, one is a list of numbers (100000 and more), another contains features which should be selected if its attribute matched a number from the first dataset.
If my assumption above was correct, a possible way is to use the FeatureMerger in this context.
  1. Send the data from the 1st dataset (list of numbers) to the Requestor port.
  2. Send the features from the 2nd dataset to the Supplier port.
  3. Set attribute to be compared to the Join On parameter.
  4. Check the Process Duplicate Suppliers if the Supplier features could duplicate on the attribute value.
The data containing a number used in the 2nd dataset would be output via the Merged port.
Hope this helps.
  • Jan 18, 2019 6:40 AM UTC
Thanks for your answer - that is that what i want
best regards
hannes
danilo_fme
  • Jan 20, 2019 1:45 PM UTC
best regards
hannes
nice feedbak, thanks!
