how to log timestamp in milli seconds in FME server jobs
  • Nov 25, 2019 3:04 PM UTC
  • 60 views
nag
Hello Team,
Can somebody help me to get timestamp in milli seconds for FME server jobs,
As of now jobs start and finish time are showing in the log as 2019-11-20 08:33:56|, I need to incorporate milli seconds also to these FME server logs.
Thanks in Advance.
Best answer by hollyatsafe
Hi @nag,
It is not currently possible to modify the format in which the timestamp is returned in the job logs. Please consider creating a new idea for this and adding any supporting comments on why you would find this useful.
The Core and Service logs also report Job Submission and Completion and these timestamps do include the fractional second, so depending your needs you may be able to use these to access the information you require.
  • Nov 25, 2019 11:32 PM UTC
Hi @nag,
