Dissolver Upgrade
  • Feb 8, 2019 10:04 AM UTC
  • 95 views
HI,
I use a FME Server 2016 to run different workbenches. For the update on FME Server 2018 I have to upgrade these workbenches, too.
Therefore I upgrade all transformers, which are upgradable. With the dissolver I get some problemes:
old workbench:
new workbench
In the new workbench I get less objects then in the old workbench, but the result must be the same.
The new dissolver has the addional parameters: Connect Z Mode, Tolerance and Aggregate Handeling.
Which are the correct configurations the get the same output like in the old workbench?
Thanks and best regards
Best answer by takashi
I think the new Dessolver should generate the same result as the previous one, by default.
Make sure that the Tolerance parameter is set to 'None' (default).
  • Feb 8, 2019 10:38 AM UTC
What you're observing is the main reason why FME doesn't automatically upgrade the transformers: to avoid any surprises in transformer behavior due to changes in the underlying transformer algorithm.
Concerning the mentioned settings :
  • Connect Z mode: this is only relevant if you have 3D data (Z values). It is also available in FME 2016 and the default value "First Wins" is identical with FME 2018.
  • Tolerance: This is a new setting in FME 2018. The default value of "None" is identical to the behavior in FME 2016. You can also read more about this setting here.
  • Aggregate handling: in FME 2016 all aggregates were automatically deaggregated. In FME 2018 you can choose to send them to the <Rejected> port instead. If you leave the setting at the default "Deaggregate" it should behave as in FME 2016.
If you still get differences, there are two things I'd recommend:
  1. Create a small sample workspace with data that reproduces the issue and send to Safe support so that they can determine if it's a regression or as expected. You can have both versions of the Dissolver transformer in the same workspace.
  2. Do not upgrade the old Dissolver transformer, leave it as-is in your workspace to avoid any changes in the output.
  • Feb 8, 2019 10:43 AM UTC
