Auto-Spin up EC2 AMI, FME, Windows Server, Engine
  • Jun 1, 2016 12:44 PM UTC
  • 81 views
I am currently running FME, Windows Server, on an EC2 instance, build #16494. I am currently adding 32 FME Engines on Separate EC2 instances to increase my processing capacity, according to this recipe: http://docs.safe.com/fme/html/FME_Server_Documenta...
Question: Does FME server have the ability to Auto Spin up one, or multiple <engineHost> machines (These would be EC2 <engineHost> AMIs) as jobs enter the queue of the <coreHost>?
That is, say I have 1 engine on the <coreHost>, and 5 jobs enter the queue. Can the <coreHost> launch one, or multiple, <engineHost> AMIs to process jobs in a queue? Such that, in this example, 5 separate <engineHost> machines would be spun up, 1 for each job in the queue.
This is important for me, because it allows me to turn off the tap, and only pay for my EC2 instances on demand. Thanks.
rylanatsafe
Forum|alt.badge.img+14
@danielc - This feature is currently not available, but you may consider investigating FME Server on Docker (Public Docker Repository) – there is a great article, Docker and FME: Driver and Worker Workflows, that I encourage you to check out!
This Knowledge Center Idea might also interest you..
  • Nov 8, 2018 9:42 PM UTC
when you scale up FME engines on docker container - how many FME engines /FME desktop licenses are required on single machine / host?
