ArcGis 10.5 licences aren't recognized anymore
  • Jan 12, 2017 9:56 AM UTC
  • 91 views
I recently installed the new ArcGis (10.5) on our system. ArcGis is working perfectly well, but since then FME isn't able to execute ArcGis related (GeoDatabase) tasks. The Error call is: Unable to check out an Esri license. Please ensure ArcGIS is correctly licensed and that there are available licenses.
Is this a known problem and what can I do to solve it (except for waiting 2 weeks for the new FME release). The only thing I can think of is reinstall the older ArcGis.
Best answer by eldertt
I found the answer elsewhere on this forum: Seems I have to upgrade to FME 2016.1.3. Sorry for bothering you all.
ngoorman
Forum|alt.badge.img+3
  • Jan 12, 2017 9:59 AM UTC
I have noticed the same thing when we upgraded to ArcGIS 10.4. It seems you need a new version of FME as well to keep them working together.
  • Jan 12, 2017 10:00 AM UTC
ngoorman
By the way you could try using the Geodatabase API reader/writer in the meantime. If you only need to to basic read/write tasks, it may be sufficient.
  • Jan 12, 2017 10:28 AM UTC
For the future, this link is the reference for version compatibility questions between FME and ArcGIS:
https://knowledge.safe.com/articles/1517/notes-on-fme-and-esri-versions-and-compatibility.html
