Fix to File Uploads on the Community
  • Jun 4, 2024 7:50 PM UTC
  • 48 views
mark2atsafe
Forum|alt.badge.img+59
Hi FME friends,
I just wanted to let you know - and test at the same time - a fix for file uploads in the community. The fix allows files with special characters in the filename. Previously it would have caused an error.
I’ve attached a test file. And here it is directly as an image:
The filename was
So, as you can see, it works with special characters just fine. Also, don’t forget to check out the new games and quizzes shown in the above screenshot.
Mark
danilo_fme
Forum|alt.badge.img+58
  • Jun 13, 2024 6:27 PM UTC
Thanks @mark2atsafe
