I would like to see an option added to FME Form where I could specify a Flow or Flow Hosted connection as my "defaults for FME Server parameters". This would make it easier when developing new Form Workspaces to test locally against the paths that my user will have access to in FME Flow or Flow Hosted. I don't think this should override the option to set these manually, but having an option on the toolbar to match them to an FME Flow, or clear them where they match the FME Flow would be useful for testing and when preparing for publishing to a multi-tier environment.
