Roadwork Impact: Construction Alert
  • Oct 24, 2024 8:00 PM UTC
  • 0 replies
  • 17 views
fmelizard
Forum|alt.badge.img+22
FME Hub user lizatsafe just uploaded a new template to the FME Hub.
Purpose & Objectives
This workspace demonstrates identifying street food vendor points that may be impacted by upcoming road construction projects. It illustrates several common spatial and tabular data processing steps.
Key Transformers
Bufferer: buffering line segments (representing noise impact areas from road construction)
AttributeValidator: validating attribute values
SpatialFilter: finding points that intersect polygons (the buffered construction areas)
Tester: filtering features based on attribute values
FeatureJoiner: joining features based on a shared key
AttributeManager: removing and renaming attributes
Data Source(s) - Reader Feature Type
road-ahead-upcoming-projects.shp Esri Shapefile - road-ahead-upcoming-projects worksheet
food-vendors CSV - CSV
business-licences SQLite - business-licences table
Data Output - Writer Feature Type
AffectedVendors Microsoft Excel - Newly created AffectedVendors worksheet
Parameters:
Overwrite Existing File set to Yes (the workbook will be recreated each time the workspace is run)
Customization
To customize this workspace, try changing the value of Buffer Distance when you run the workspace. This user parameter allows the end user to affect how the workspace runs. Increasing the distance will mean more food vendors are included in AffectedVendors.
Additional Resources
Sign up for the free, interactive FME Accelerator workshop to learn more about this workspace and learn the basics of automating your data integration workflows and connecting to 450+ formats.
For help with this workspace, please contact Safe Software Support and reference Roadwork Impact: Construction Alert Gallery Example.
Would you like to know more? Click here to find out more details!
