ArcGISPortalTokenGenerator
  • Feb 20, 2024 4:00 PM UTC
  • 0 replies
  • 72 views
fmelizard
Forum|alt.badge.img+22
FME Hub user sashal just uploaded a new transformer to the FME Hub.
Generate an Esri ArcGIS Enteprise Portal Token
This transformer generates a token for ArcGIS Enterprise. The custom transformer uses the httpCaller transformer to make a REST API call to the ArcGIS REST API and outputs the token generated as an attribute. All attributes needed to populated the REST call are parameterized.
Would you like to know more? Click here to find out more details!
