jsontemplater turns 2-decimal number 1.21 into 1.2100000381469727
  • Apr 16, 2026 12:27 PM UTC
  • 8 replies
  • 153 views
arnovananrooij
Forum|alt.badge.img+5
I use a JSONTemplater to make a geojson with nested attributes. It works fine. The only thing I notice is that I have a number in real32 (1.21) and when it comes out of the JSONTemplater it has the value 1.2100000381469727. The extra decimals apear out of nowhere. How can I change these back to the original? Or can I use some kind of casting?
I use FME 2023.2.5.
Thank you
Best answer by david_r
Is it possible that your value is either null or missing when you get this error?
Try using something like this in the JSONTemplater, which will handle null and empty values:
"value": if (fme:get-attribute("value") castable as xs:double)
then fn:round(xs:double(fme:get-attribute("value")), 2)
else ()
  • Apr 16, 2026 1:23 PM UTC
You can use XQuery expressions inside the JSONTemplater. Example rounding the attribute "value" to two decimals:
{ "value":{fn:round(xs:double(fme:get-attribute("value")), 2)} }
Result:
{ "value" : 1.23 }
You can find a reference of all the XQuery and XPath functions here: https://www.w3.org/TR/xpath-functions-31/
s.jager
Forum|alt.badge.img+27
  • Apr 16, 2026 1:48 PM UTC
Hoi Arno,
Both the JSONTemplater and the XMLTemplater “suffer” from this problem. There is a good explanation for it though, which you can find in this thread: XMLtermplater vs. XSD-driven and a little problem | Community
  • Apr 16, 2026 2:33 PM UTC
Just to provide some background, this “problem” is not related to FME but to floating point precision in general, and how computers represent floating point numbers internally. Basically, floating point (real) numbers cannot, in general, be accurately represented in fixed space such as binary. This means that all floating point rounding errors cannot be eliminated, only managed.
Some systems go to great lengths to hide (manage) these imperfections from the users, including Python and FME, but we can sometimes, inadvertently, cause cracks in the façace and we end up with the real, internal value, and you get something like 1.2100000381469727 rather than the expected 1.21.
This is a fairly good introduction:
arnovananrooij
  • Apr 23, 2026 12:52 PM UTC
Result:
{ "value" : 1.23 }
Hi ​@david_r ,
Thank you for your reply.
I tried your suggestion, bur this gives an error: JSONTemplater_2 (XMLTemplaterFactory): "xs:string": invalid value for cast/constructor: can not cast to "xs:double". How can I fix this.
  • Apr 23, 2026 12:57 PM UTC
else ()
arnovananrooij
Hoi Arno,
Hi ​@s.jager  I had a look at the thread you pointed to and tried {fn:format-number(xs:double(fme:get-attribute("numberAttribute")), "0.00")} instead of the fn:round suggestion by David. This also gives me an error:  "xs:string": invalid value for cast/constructor: can not cast to "xs:double".
Maybe the problem in my case is that the attribute can be null.
arnovananrooij
Result:
{ "value" : 1.23 }
Hi ​@david_r ,
Hi ​@david_r , I solved it by adding a NullAttributeMapper to convert every null and empty value into missing and used your solution in de JSONTemplater.
Thank you
arnovananrooij
Hoi Arno,
​@s.jager  I added a NullAttributeMapper to convert all null values to missing. Then your solution works, but it sets all values into two decimals so I used fn:round suggested by David, But thanks for your suggestion.
