Reading attributes from JSON response
  • Mar 5, 2026 11:55 AM UTC
  • 112 views
havmoejbv
Forum|alt.badge.img+16
I have JSON response from an API that looks a bit like this (tidied up for the purpose of showing here):
"member": [
"id": "OBF-123",
"fieldspec": [
"assetattrid": "FIELD01",
"assetattribute": [
"datatype": "NUMERIC",
"description": "Length"
"numvalue": 13.4
"assetattrid": "FIELD02",
"assetattribute": [
"datatype": "ALN",
"description": "Fruit type"
"alnvalue": "Banana"
"assetattrid": "FIELD03",
"assetattribute": [
"datatype": "ALN",
"description": "Class"
"alnvalue": "N"
"id": "OBF-124",
"fieldspec": [
"assetattribute": [
"datatype": "ALN",
"alnvalue": "Apple"
"assetattribute": [
"assetattribute": [
"datatype": "ALN",
"alnvalue": "K"
This defines the attributes for two objects returned from an API request, containing the field name (assetattrid) and alias (description), the field type (datatype) and finally the actual attribute value (numvalue/alnvalue). What I would like is to get properly named attributes like this:
id Length Fruit type Class
OBF-123 13.4 Banana N
OBF-124   Apple K
A few complicating factors (and why I’d like to find a dynamic solution):
  • The attributes (names, types and amounts) may be different depending on the data queried (different object types, query parameters etc)
  • Some fields might be empty, like the missing numvalue for object 2 above, but the field definition seems to always be there
  • The field order appears to be random
Best answer by hkingsbury
Find attached an example workspace (2024.2)
Its a pure dynamic workflow, so everything is data driven (exception of the ‘id’ field in the output)
The general logic is to:
  1. break down the incoming json so that each field in each record is a fme feature
  2. Create each feature using description as the attribute name and (aln|num)value as the attribute value
  3. Aggregate these back based on the id in the JSON
  4. Take one example of each field, build an fme schema object for them
  5. Join the schemas back onto the records
  6. write out (to csv) using the schema attached to the feature
hkingsbury
Forum|alt.badge.img+73
  • Mar 5, 2026 7:27 PM UTC
havmoejbv
  • Mar 6, 2026 9:12 AM UTC
Oh, very nice! This seems to be working fine on the test data on my end and solves a massive headache I’ve had. Thank you!
danilo_fme
Forum|alt.badge.img+58
  • Mar 6, 2026 9:20 AM UTC
Good job!
