Folder path with special characther å does not work
  • May 29, 2018
  • 45 views
I'm trying to upload a file from a folder with name luleå but FME change the character å with \\xE5 in the folder path and FME cant find the file and terminate the workbench.
Is there something to do so fme does not change the character?
  • May 29, 2018
If i change the folder not contain the character å it works but I cant do that.
jkr_wrk
Forum|alt.badge.img+37
  • May 29, 2018
Maybe you can use the DOS filename LULE~1
I have tested it with a filename ὅ1.txt what looks like 1C2E~1.TXT in using DIR /X in CMD. And my FeatureReader is able to read the file.
fmelizard
Forum|alt.badge.img+22
  • May 30, 2018
The DOS filename will work. But we have an opportunity to do something better here long run. Short run the DOS filename is the best workaround sorry.
