Dynamic writer dropping record - with no warning logged
mattebridges
Forum|alt.badge.img+8
Hello all - grateful for some suggestions here - I’m being driven slowly mad…
We are developing a ‘data portal’ style workbench running in FME2025.1, using a dynamic writer to deal with multiple input and output datasets and multiple possible output formats - the dataset and output format are specified by user parameters.
The source datasets are point or polygon datasets stored in an MSSQL Esri SDE and output formats  include all the usual GIS data formats.
This is generally working well but one polygon dataset is failing to wite out. In this case the log reports the following:
Feature output statistics for `GENERIC' writer using keyword `GENERIC_1':
                           Features Written Summary
Total Features Written                                                       0
                            Features Read Summary
Total Features Read                                                          0
        1
Total Features Written                                                       1
It appears that the record reaches the dynamic writer but it is then silently dropped and not exported - there are no relevant warnings shown in the log.
The approach that we are using in the workbench is consistent with other datasets from the same source database and it works fine for all of these.
I’ve checked the following:
  1. schema feature is present on the record - same approach used for other datasets in the workbench
  2. there are no contentious attribute names
  3. geometry is valid (currently stored in MSSQL Esri SDE - and a GeometryValidator is included in this workbench)
  4. the data writes out successfully with a non-dynamic writer
I can’t see anything different in the way this dataset is handled within this workbench when compared to the other datasets that are working well. I also can see nothing in the data itself to explain why it would be rejected by the dynamic writer across all formats (including even CSV).
Has anyone else encountered anything similar or able to suggest anything further I can try.
Thanks in advance.
nielsgerrits
Forum|alt.badge.img+67
Can you try a more recent version of FME? Not sure if this is related but there were issues with dynamic writing in the earlier 2025 versions. It got better in 2025.2.
https://community.safe.com/authoring%2D6/fanout%2Din%2Dwriter%2Dfails%2D2025%2D1%2D1%2D38934
mattebridges
Thanks for the suggestion ​@nielsgerrits - I’ve tried with 2025.2.3.0 and still getting the same issue.
As a workaround I could add a static writer per format for this dataset and route output accordingly using the parameter value but it seems a shame to have to do this and would be good to understand what’s happening.
mattebridges
I’ve just come back to this issue and I think what is happening is that the dynamic writer is sourcing the schema from the first record and then dropping it. I hadn’t noticed that all output files were missing one record.
The specific dataset that I had an issue with previously only contained one record so nothing was being written out.
My workflow currently uses a schema scanner to create the attribute{} list to provide the schema and this list is then merged to all records. This is enabling the dynamic writer to create the schema but I now need to work out how to stop the writer from dropping the first record.
I have tried supplying the schema feature as the first row to hit the writer but am finding that this only works if the schema list is also merged to all other records as well. Is this actually the correct workflow for dynamic writers - or is there a more straightforward approach?
nielsgerrits
The way I do this is not by merging the schemafeature, but making sure the schemafeature arrives at the featurewriter before the datafeatures by using a Sorter.
mattebridges
Great - and thanks for replying.
The approach I’ve been using was with a sorter as you’ve described, but I think the writer was failing unless I also merged the schema list on to the other records.
That did feel like it wouldn’t be necessary though and perhaps it was failing for another reason. I’ll take another look ASAP.
I really appreciate you taking the trouble to reply.
debbiatsafe
Forum|alt.badge.img+24
Hello ​@mattebridges
Are you able to check if the schema attribute fme_schema_handling is present on the feature that is supposed to be written? From what you have described, I suspect it is and its value is schema_only.
This is a special attribute that is added to the schema feature by SchemaScanner and the schema_only value tells a dynamic writer to use that feature as schema and drop it from the output.
If you want to avoid this, you can either remove the fme_schema_handling attribute or set its value to schema_and_data before merging the schema feature to data features.
