Function @uuid() versus transformer UniqueIdentifierGenerator
  • February 16, 2024
  • 106 views
andr__d
Forum|alt.badge.img+5
Hello,
Is the result of the function @uuid() the same as the transformer UniqueIdentifierGenerator ?
I would like to create directly an UUID in an attribute creator instead of using 2 transformers (UniqueIdentifierGenerator and AttributeCreator).
Thanks.
Best answer by itsmatt
Essentially yes,
If it helps, I use it all the time in attribute creators to create gml_id’s.
Usually in the form of:
ID_@UUID()
the rest of the stuff in the function isn’t needed
itsmatt
Forum|alt.badge.img+47
  • February 16, 2024
Essentially yes,
ID_@UUID()
