Expose all attributes
  • Mar 17, 2026 6:20 AM UTC
  • 5 replies
  • 309 views
deanhowell
Forum|alt.badge.img+24
There are a series of similar posts but still not seeing a way to expose attributes dynamically.
I have a a large number of geodatabases which have multiple layers and different attributes, which I am merging with a geometry layer so I end up with a single layers with lots of attributes.
The geodatabases have a series of tables and a geometry layer, but there is no consistency in attributes between the geodatabases.
How do I expose and have these exposed attributes output to a merged dataset?
nielsgerrits
Forum|alt.badge.img+67
There is no such thing as dynamic exposing attributes in FME. But for dynamic writing you can use a Schema Feature.
One way to do this is to use a SchemaScanner, to generate a Schema Feature and feed that to a FeatureWriter set to Dynamic Schema Definition.
It is always a bit of a struggle to set this up. The Schema Feature much arrive at the FeatureWriter before the data features, but it does work. I can provide a sample if needed.
  • Mar 17, 2026 7:47 AM UTC
Just to add to what ​@nielsgerrits said: Exposing attributes is a design-time aid for the developer and not a binding schema contract. Due to the highly dynamic nature of FME workflows, whatever was exposed at design-time may not necessarily correspond to the situation at run-time.
Also, exposing large amounts of attributes (typically when trying to account for every type of feature class in a large dataset) will push memory consumption in FME and potentially also slow down both the design and execution time.
Look into and embrace dynamic workflows. Safe provides a really good tutorial series, here is the starting point:
https://support.safe.com/hc/en-us/articles/25407480725645-Tutorial-Dynamic-Workflows
  • Mar 17, 2026 7:53 AM UTC
If possible, I would recommend using the FeatureReader in place of the classic readers. It will automatically provide the schema feature based on the source dataset definition without the guesswork of the SchemaScanner transformer.
ed-progres
Forum|alt.badge.img+5
  • Aug 27, 2026 1:24 PM UTC
I love FME for what it CAN do.
I hate FME for what it CAN'T do. Auto exposing attributes is something I really would like to see.
  • Aug 28, 2026 11:06 AM UTC
How could FME Workbench know anything about attributes for datasets it hasn’t seen yet? Or am I missing something?
