@getFileName(@zip(OutputLocation))}
  • September 26, 2022
  • 65 views
sigtill
Forum|alt.badge.img+25
This should still work
<fmeblock>
<p style="font-family: Arial; font-size: 11px;">Din bestilling (id {id}) av data er nå ferdig produsert. Resultatdatasettet er tilgjenglig i 24 timer og kan lastes ned fra<br />
{urlPrefix}{ResultRootDir}/{@getFileName(@zip(OutputLocation))}
</p>
</fmeblock>
However when used in 2021 it still says: https://fmeserver.com/fmedatadownload_undefined_/_undefined_
Is this not valid anymore?
According to this: https://docs.safe.com/fme/2022.1/html/FME_Server_Documentation/ReferenceManual/EmailTemplateLanguage.htm#Function
Best answer by sigtill
Replacing:
with
{urlPrefix}{ResultRootDir}/{@getFileName(OutputLocation)}
Seemed to fix the problem!
sigtill
  • September 27, 2022
Replacing:
with
tono
Forum|alt.badge.img+13
Replacing:
with
It works, but any one at @safesoftware safesoftware​  can answer why? it should be (and it works at least on FME Server 2020.0.2.1 Build 20238 - win64) with:
siennaatsafe
Forum|alt.badge.img+12
Hi @tono​,
I looked into this. I can't find out when the @zip function was officially removed. However, in 2016.1 we removed it from our documentation. The note at the time was the @zip function did not work anymore.
See https://docs.safe.com/fme/2016.0/html/FME_Server_Documentation/Content/ReferenceManual/Email_Templates.htm
and
https://docs.safe.com/fme/2016.1/html/FME_Server_Documentation/Content/ReferenceManual/Email_Templates.htm
I'm not sure what caused it not to work again in 2021 but I'm honestly surprised it worked in 2020.
