Arrays of Referenced Objects in Data Virtualization
  • Apr 8, 2026 6:54 PM UTC
  • 189 views
mhom
Using $ref in FME Flow Data Virtualization APIs for Deduplication
This might be an imprecise post, but my question is whether FME Data Virtualization follows the exported API specification or the visual editor’s interpretation - and why. I need guidance on restructuring my specifications: Data Virtualization seems to accept arrays of schema references but silently drops them, replacing them with blank references in properties but losing the json-type array in endpoint responses.
This inconsistent handling of $ref makes it unclear how Data Virtualization processes schema references — especially for arrays, since the visual editor only supports $ref for objects.
Thanks for taking the time in advance!
EDIT: Im am currently using FME 2025.2.4 Build 25835
The Use Case of Arrays with $ref
Here is an example usage of Arrays of Referenced Objects from the OpenAPI spec. I use the schema /pet a lot for Deduplication. Also having Arrays of type pet. How would one achieve this in FME?
4.7.8.3 Paths Object Example
"/pets": {
"get": {
"description": "Returns all pets from the system that the user has access to",
"responses": {
"200": {
"description": "A list of pets.",
"content": {
"application/json": {
"schema": {
"type": "array",
"items": {
"$ref": "#/components/schemas/pet"
/pets:
get:
description: Returns all pets from the system that the user has access to
responses:
'200':
description: A list of pets.
content:
application/json:
schema:
type: array
items:
$ref: '#/components/schemas/pet'
If I understand this correctly, the schema used for the response is of type array with 1 property ‘items’ that references to a scheme ‘pet’ for pets.
So to break it down its array → items → $ref/pet
the expected response would be somthing like this:
    "name": "Doggo",
    "age": 2
    "name": "Kitty",
    "age": 3
So to build this kind of response i would either use an array as response and reference the pet schema or create an schema petArray and use it in the Response Structure.
If you were to create an response of json type array, you cant select a schema. So you would have to create the pet item inline by defining the existing properties again leading to duplication. But, you would get the expected response.
"name": "Doggo",
"age": 2
If you chose object as the json type for your response you can’t create a property of type array with the array type of pet either as you can’t reference the type of the array to an existing schema. Object arrays are allowed in general but then there would be no documentation of the objects (pet) in it.
If you chose object as the json type for your response and create a property, you could reference to an existing schema leading to my approach of petArray. But we have the same issue with schemas of type array again - no arrays of a referenced type allowed.
So i chose array of type object, created a property of type schema referenced pet and named the property “ref’. In the spec  would normaly use something like items for arrays, but as this is not fitting and because a property name is required for $referenced schemas as well, i just chose “ref”.
Now i was curious what i would get as a response, because I thought  $ref works by replacing itself and everything on its level with the definition it is pointing at.
So i named this one “ref” again and selected petArray and get this response:
"ref": [
"ref": {
"name": "Doggo",
"age": 2
So instead of a clean unnested response (the response i wanted to achieve) this now has additional brackets, and more problematic the references not replacing themself.
This is what i want:
    "name": "Doggo",
    "age": 2
    "name": "Kitty",
    "age": 3
I wondered, can you import such references as json-type response? Set up this fictious PetApi Spec and imported it.
"openapi": "3.0.3",
"info": {
"title": "Pet API",
"version": "1.0.0"
"paths": {
"/pets": {
"get": {
"responses": {
"200": {
"content": {
"schema": {
"type": "array",
"items": {
"components": {
"schemas": {
"pet": {
"type": "object",
"properties": {
"name": { "type": "string" },
"age": { "type": "integer" }
"required": ["name", "age"]
"PetArray": {
"type": "object",
"properties": {
"pets": {
"type": "array",
"items": {
"required": [
"pets"
No errors, just a quiet warning that i found in the datavirtualization.log (not the petApi log itself).
WARN No request body to import for endpoint GET /pets.
If we look at the endpoint, pets just references to pet, the type “array” gets lost.
If we look at the schema petArray, the reference is also lost, leaving the type blank with <Choose type (optional)>.
So if the visual editor doesn’t show type array in the response i expected fme changed it in the OAS. I Exported the OAS immediately after importing without tampering within the editor. No changes:
"openapi" : "3.1.0",
"info" : {
"title" : "Pet API",
"description" : "",
"version" : "1.0.0",
"summary" : ""
"servers" : [ {
"url" : "api/petApi"
"paths" : {
"/pets" : {
"get" : {
"tags" : [ ],
"summary" : "",
"description" : "Returns all pets from the system that the user has access to",
"operationId" : "getPets",
"parameters" : [ ],
"responses" : {
"200" : {
"description" : "A list of pets.",
"content" : {
"application/json" : {
"schema" : {
"type" : "array",
"items" : {
"$ref" : "#/components/schemas/pet"
"components" : {
"schemas" : {
"pet" : {
"type" : "object",
"description" : "",
"properties" : {
"name" : {
"type" : "string"
"age" : {
"type" : "integer",
"format" : "int32"
"required" : [ "name", "age" ]
"PetArray" : {
"type" : "object",
"description" : "",
"properties" : {
"pets" : {
"type" : "array",
"items" : {
"required" : [ "pets" ]
So does FME Flow now stick to the exported Specification and if so do i now have an array of referenced schemas? If not, why doesn’t it change the Specification and therefore documentation accordingly?
using duplicated inline properties to define a response of json type array
using a property of type array you can’t reference the type of the array to an existing schema
using a property of type schema leads to nested json response as a name for the property is required
petArray with property called ref with type <Use Schema>
after importing specification of Array of Referenced schema ‘petArray’ it says ‘Choose type (optional)’ instead showing the referenced schema ‘pet’
Best answer by dylan.at.safe
Hi ​@mhom,
We are aware of the missing functionality regarding not being able to refer to an existing schema within an array. Our internal reference for the issue is FMEFLOW-26534 - Use Saved Schema in a JSON Array. I’ll add your comments to the ticket to let the development team know you are interested in this functionality.
The WARN No request body to import for endpoint GET /pets. message seems to be triggered on every GET endpoint, regardless of the response schema shape. I’ll check in with our development team to see if there is an enhancement there.
Lastly, we’ll have to do some further investigation on the discrepancy you are seeing between what shows up in the UI, OAS and what the response actually returns. All this information has been very helpful in understanding the issue. Thank you for the detailed investigation!
carlw
Forum|alt.badge.img+11
  • Apr 10, 2026 5:48 PM UTC
Hi mhom,
Welcome to the FME community :) Thank you for sharing such a detailed report - it’s great to see users digging deep into Data Virtualization like this.
May I ask what version you are currently using? There have been some significant updates to Data Virtualization since it was first introduced in 2025.1 so I just want to make sure we’re all on the same page!
Carl
mhom
  • Apr 14, 2026 5:49 AM UTC
Hi Carl,
thanks for your reply. :)
That's good to know. With that in mind I briefly scanned the changelog specifically 2026.1 but couldn’t find anything related. Am I missing something?
I’m currently using 2025.2.4 Build 25835, thanks for pointing that out - I totally missed that!
mhom
dylan.at.safe
Forum|alt.badge.img+9
  • Apr 24, 2026 10:57 PM UTC
Hi ​@mhom,
