Upsert - recommendation on how to use?
  • April 10, 2026
  • 110 views
vxn43
Forum|alt.badge.img+20
I have an address feature class in a SQL Server 2022 Enterprise Geodatabase.
Some records have been updated in the attribute table and new records have been added.
I want to write these updates and additions to another Enterprise Geodatabase and a File Geodatabase.
Would the recommended approach be to use a ChangeDetector before each Writer and then use Upsert in each Writer?
OR
Can I use Upsert in each Writer without using ChangeDetector?
Currently, the way I do this is to Truncate Existing in the Writer for the Enterprise Geodatabase and the Writer for the File Geodatabase. But, this can take a long time to run. It seems more efficient to use Upsert.
Best answer by hkingsbury
Depending on the volume of features, it still may be worth running the change detector first.
Upsert works on specified ID, if the ID exists, an update happens, if the ID doesn’t exist, an insert happens.
It doesn’t check any other attributes, so you’d be running an update against a feature that doesn’t need updating with the same values/geometry
hkingsbury
Forum|alt.badge.img+73
  • April 12, 2026
