Write multiple geometry types as geopackage
  • March 18, 2024
  • 322 views
Hello all,
When trying to write my data as a geopackage I get the following warnings (see attached).
In the reader I have to specify what geometry type I want to use but I can only select one, which results in some features being excluded.
I have read a thing about the dynamic writer but that one is giving me errors.
Using the GeometryFilter the only type I get is ‘area’ so it doesn't seem to make a distinction between those.
Is there a way to write these different geometry types in one Geopackage layer? I am using version 2020.0
nielsgerrits
Forum|alt.badge.img+55
Yes you can, but not all applications like multigeometrycollections, so the result might not be what you need.
Set the geometrytype in the writer to geopackage_geometrycollection.
