Prevent Logging of authorization header with HTTPCaller
olyster
When using HTTPCaller with an authorization header with a bearer token, the token appears in the log.
How can I prevent this ?
I’m using FME desktop and server version 2021 so LOG_FILTER_MASK doesn’t work. Updating the version is not a solution. The bearer token is obtained at runtime so I can’t put it in a private parameter (PP cannot be updated at runtime).
Thanks.
Best answer by hkingsbury
That’s fine, when you publish it up to FME Flow (Server) the log settings of the Workbench/Form it was published from will be included when it runs on Flow.
At the desktop level, the logging is an FME Form/Workbench application setting, not a workspace configuration flag
hkingsbury
Forum|alt.badge.img+55
  • January 7, 2025
Hmmmm You could disable logging entirely, but then you’ll have no logs…
Could you transition to using a webconnection to authenticate against your service? If its using Oauth you can setup your own webconnection for it: https://support.safe.com/hc/en-us/articles/25407422190861-Creating-an-OAuth-2-0-Web-Service-and-Connection-in-FME
olyster
  • January 7, 2025
Thanks for your answer.
How could I disable logging entirely for my .fmw only?
I’m not an administrator on the FME server machine nor have I access to the web service using bearer token authorization.
hkingsbury
  • January 7, 2025
Under FME Options > Translation > Log Message Filter you have the option to specify what level of logging you want for Form (Desktop).
In your instance, you should be fine un-ticking Information and leave Errors, Warnings and Statistics enabled
Once you’ve updated that, you can then publish to Flow (Server) and the workspace will maintain those log levels.
The setting you changed is a Form (Desktop) level setting, so it will apply to the application, and any subsequent workspaces you open will adopt that level of logging. Therefore, it is a good idea to go in and revert back to previous settings once you’ve published the workspace.
To help make sure that subsequent Republishes for that one workspace are updated with the correct logging, it is a good idea to have an annotation in the workspace specifying that Information logging needs to be disabled before publishing to Flow (Server)
olyster
  • January 7, 2025
Thanks for your answer hkingsbury,
This approach doesn’t change the fmw file. Is it supposed to work with FME 2021 desktop and server versions ?
hkingsbury
  • January 7, 2025
virtualcitymatt
Forum|alt.badge.img+39
I’m curious where you see it being logged.
I would also second the suggestion of the web connection if that’s at all an option.
If the token is used as a Published Parameter you could make the token be of type “Password”. FME will then treat it as ‘*’ in the log
olyster
  • January 8, 2025
hkingsbury : I think that this is the only option but unfortunately I don’t have the necessary permissions in production environment. I’ll try in staging (if possible since our deployment is done via teamcity) and if it works, I’ll ask for it to be published from FME Desktop.
virtualcitymatt: The token is obtained at runtime with a first call to another HttpCaller (which displays the basic authentication encoded in base64 which is also annoying cause it’s easily decryptable and there’s no ways of hiding it with all the constraints I’m facing). I then call another HttpCaller with the token which appears in the log:
User-Agent: FME/2021.7.42.21821 libcurl/7.79.1 (OpenSSL/1.1.1n) Schannel zlib/1.2.11 WinIDN ibssh2/1.9.0 nghttp2/1.44.0
Accept: */*
Accept-Encoding: deflate, gzip
Authorization: Bearer eyJhbGciOiJSUzI1NiIsImtpZCI6IjA4…
Look further down in the log when the http call is actually happening. If it doesn’t appear, I guess another solution would be to create a custom transformer and passing the token as a parameter of type password. I’m gonna try and let you know.
Thanks to both of you for your answers/inquiries. The solution is always to never give up !
virtualcitymatt
olyster wrote:
Accept: */*
This honestly looks like a debug log - this isn’t usually logged unless debug logging is on. Check the settings to make sure that FME Debug logging is not checked
olyster
  • January 8, 2025
virtualcitymatt : The goal is to avoid the token to be displayed in FME server log which is the case now. As stated I don’t have to necessary persmissions on our fme server 2021 to modify this setting. If I did, would it be possible to change it only for this specific fmw ?
Version 2022 is using LOG_FILTER_MASK but I don’t know when our server will be updated.
