Polygon from XYZ values
  • June 18, 2013
  • 26 views
Hi, I have XYZ values and I need to create a DGN or SHP polygon based on the min and max X and Y values.
What is the easiest way to do this?  I tried to use BoundsExtractor and 2DBoxReplacer but it doesn't seem to be working.  Any other ideas?
Thanks,
Best answer by takashi
If you need to create a minimum rectangle polygon including all of coordinates, use the BoundingBoxAccumulator after replacing coordinate values with point geometries through the 2D or 3DPointReplacer.
Takashi
  • June 18, 2013
Takashi
