Polygon Around Raster Image
  • February 21, 2019
  • 146 views
Hi all,
Does anyone know of an easy method to create a polygon around part of a LiDAR tile where the LiDAR tile does not have a complete set of values or is not complete?
So in the example below I would like to create a polygon around the colored sections (crudely drawn in red), not the whole tile.
I have tried the RasterExtentsCoercer, but that just creates a polygon over the whole tile.
Thanks all.
Best answer by daveatsafe
Hi @juffers,
Please use a RasterExtentsCoercer transformer, with Extents Type set to Data Extents. This will create a polygon around the data areas of your raster, excluding any Nodata pixels.
daveatsafe
Forum|alt.badge.img+20
  • February 21, 2019
Hi @juffers,
  • February 22, 2019
daveatsafe wrote:
Hi @juffers,
Hi @DaveAtSafe, That's exactly what i was looking for, thought it would be something simple like that. Appreciate the help.
nicholas
Forum|alt.badge.img+14
  • June 23, 2019
The RasterExtentsCoercer is great :-)
But I have lots of individual pixels that have nodata values, that form small holes inside your large polygon.
I suggest you also use DonutHoleExtractor to remove these small holes
