Mesh with existing polygons.
  • March 6, 2015
  • 20 views
So I have a model that builds polygons off legal descriptions. Long story short is mine don't (always) line up with the auto-mapped polygons that have been previously mapped. Is there anyway to maybe tell the polygon to snap to the nearest edge/vertices? Attached is an example of such, looks a lot worse once you start to zoom in obviously. There is even some alignment problems on the top right as well. (grey polys are mine, yellow existing). I appreciate your time.
  • March 7, 2015
The AnchoredSnapper (Snapping Type: Vertex Snapping) might help you.
Try, send the yellow polygons to the Anchor port; send the gray polygons to the Candidate port.
Takashi
  • March 10, 2015
Yes, unfortunately the result is quite catastrophic, the end result produces some very jagged polygons I've tried messing with the tollerence but no luck.
